Icon for web page shortcuts
In regular Firefox on Android, if I save a page to my home screen, it uses the favicon of the website as the icon of the shortcut. But in Firefox Focus, I get a purple square with the first letter of the domain name instead. Is there any way to change the icon to something more appropriate?
Hi
Firefox Focus is designed for anonymous on-device browsing and so that approach is designed to make the shortcut a little less obvious as to it's target.
That said, you may wish to try the private browsing mode in the new Firefox Preview browser that uses a websites favicon in the home screen shortcut.
Thanks. My purpose isn't privacy per se - I simply like FF Focus for basic browsing because it's light and nimble on my cheap phone. I normally just use Firefox when I need cookies. But it's not a big deal either way - I can either just get used to the purple squares or use Firefox for some that I have trouble spotting among my apps.
Ironically, it seems that Focus has a feature that Firefox doesn't: When I made the shortcut in Focus ("Add to Home screen"), it allowed me to change the name, but when I did it in Firefox ("Page" -> "Add to Home screen") it just used the page title with no option to edit it. I assumed Focus was stripped down from Firefox, but apparently it has some hidden gems.
Perhaps someday Android itself will have a way to edit shortcuts like in Windows (and presumably other desktop OSes), to rename and choose icons.
Ok, thank you for your feedback, I am glad to hear that you like using Firefox Focus.
